Cooling Performance
For cases with a CPU cooler clearance of less than 65mm, we use our super low-profile mini-ITX test kit. which includes:
We use our ATX power supply if possible, but switch to the SFX model if not. The CPU fan is fixed at 12V with a Molex adaptor while the graphics card fan is locked at 40 percent speed using MSI Afterburner. The system is loaded using Prime95 25.11 and Unigine's Heaven 4.0 benchmark. We use HWMonitor and GPU-Z to monitor the temperatures, taking the maximum values after 15 minutes - enough time for the readings to plateau.
In cases that can house a discrete GPU, we obtain thermal results with both the CPU portion of the APU and the discrete graphics card under load as described above. However, we also perform a separate test where only the APU is stressed, again using Prime95. This way, we'll be able to compare APU results for a wider range of cases, but also allow you to see how larger cases perform when a discrete graphics card is added to the mix.
        No case - open test bench
        SilverStone Raven RVZ02 (horizontal)
        SilverStone Raven RVZ02 (vertical)
          20
          30
          40
          50
          60
          70
          80
    °C, lower is better
          20
          30
          40
          50
          60
          70
          80
    °C, lower is better
        Cooler Master Elite 130
        SilverStone Sugo SG13
°C, lower is better
